Create a sketch from Adobe Illustrator {*.ai] file
Has anyone succesfully imported an ".ai" file from Adobe illustrator? While in Sketch Mode > Data from File, one has access to Adobe Illustrator {*.ai] format.
Whenever I try to access one of these files to my sketch nothing happens?
Any suggestions?
Thanks.
Wildfire 2.0 - m130
Any suggestions?
Thanks.
Wildfire 2.0 - m130
RE: Create a sketch from Adobe Illustrator {*.ai] file
Depending on the complexity of the drawing, you might have a really tough time bringing this in, since Sketcher still has to apply dimensions and constraints to the imported geometry.
One thing you can do is divide up your drawing in Illustrator into separate layers, and then export it step-by-step. This eases up the load on sketcher.
I've found in Pro that AI V10 and AI CS2 format doesnt work but V8 and V9 will import with all entities.
W.Y.T.D.N.T.Y Manual coming soon :)
"if you can't make it work...Cheat"
HP workstation xw6200
-Intel Xeon (cranford) 3.2GHz 800MHz Bus
-DDR2 PC3200 4x512MB Infineon RAM
-ATI FireGL V7100 256MB GDDR3
Driver Version: 6.14.10.6483
-Solidworks 2006 SP3.0
-Soldiworks 2006 SP4.0
-Rhino 3.0 SP4
Do you think that is my problem?
