exam solution ??
exam solution ??
exam solution ??
i need a solution of this question
for an air standard cycle atmospheric air is at 27C it is compressed to the high pressure and then cooled to 30C . the turbine exhausts air at 7 C the air leaving the space is at 11 C if the space is 17 KW  determine 1-air flow rate ,2-motor power ,3-high pressure, 4- C.O.P
i dont know if am i right
Q= m cp (T4-T1)
m =17/(1.005(16))
p1=101kpa   (P2/P1)^(n/n-1)=(T2/T1)
                 n=1.4
i dont know T2 i cannot complete.
thanks all
RE: exam solution ??
Why?
TTFN
why what?
if any one know any thing plzz ,,i am desperate
ETCHYHA: There is not enough information.  You need at least: the compression ratio, the volumetic efficiency and the rpm of the engine.
Dave Hall
If this is a homework assignment, you should not be using this forum.
If this is an exam question, you should be doing it yourself?
Eng-Tips.com Forum Policies
FAQ731-376
it is neither a 'H.W.' nor currently exam it is an old ex. wanted desperatly to know  its answer
ask your prof, they'll help with examples
What do you mean when you say space is 17kw?  This sounds like the work output of the turbine.  When it comes to thermodynamics if you don't do the homework you won't catch on. You may even wind up working in a gas station.
guys u took that quest.sooo hard on yr selves ease it up i'm a graduated engineer & getting any info. about any thing after graduation is not easy at Egypt my country . any way i get the answer thanks god and
thanks  to all,,,
