model flips around when cancelling operation
Often I have a complex model, and I will be zoomed up doing an operation, and then decide to cancel it. Then, Pro-E zooms the model out, and flips it to some unknown orientation. It takes time to get it back to my original orientation. Is there any way to stop the zooming out and flipping when I cancel an operation?
RE: model flips around when cancelling operation
Alternatively, save your view while you are working, so if Pro/E does "flip out" on you (lol) you can just jump back to that view...
mapkey pv @MAPKEY_LABELPrevious View;~ `View`;\
mapkey(continued) ~ Activate `main_dlg_cur` `View.OrientationCascadeBtn`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_prev`;
<tg>
Search back through this forum for some detailed discussions of mapkeys.
Best of luck
I made the mapkey per your direction, and it works! Thanks!
