PDMWorks file explor. question?
Hello fellow engineers and designers,
I like to relieve my work directory infrequently and would like to know if in more recent versions there is the ability to control select(multiple)files in your work directory for deletion?
I am using sw 2005 sp 3.1
PDMWorks 2005
regards,
dsgnr1
RE: PDMWorks file explor. question?
I am using PDMWorks through SolidWorks.
there is a file folder located on the right side of the screen.  From here I am accessing the file explorer in the PDMWorks module (while working in Solidworks).
My problem is when I go to clean out my work dir. I can only delete one (1) file at a time.  Working in this module has it's advantages too, because you can see in real time if the file you are about to delete is = to the vault.
I would like to be able to control select (hold down control key) and select multiple files for deletion.
I will type up an enhncement if this is not available in more recent versions than I am running.
pdmw 2005
thanks for the reply,
dsgnr1
Ah, I see. I have not been able to delete that way also, only one at a time. A good Enh.Request. I do not know if it has changed for 2006. Maybe someone has a macro or API to do this?
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
