Biomass drying
Biomass drying
Hi
I need to calculate heat demand for biomass drying. I know its weight and properties. For this purpose I would like to use some kind of outside floor heting. Any ideas?
Chris
Chris
RE: Biomass drying
RE: Biomass drying
RE: Biomass drying
RE: Biomass drying
http://www.nrel.gov/docs/fy99osti/25885.pdf
RE: Biomass drying
Thermcools' statement on rough approximation is correct - except I don't understand what He means by "heat absorbed by bulk biomass" and "loss to the ambient".
While as a unit operation Themcool is correct on rough approximation as a single step process. However a more complex precess arrangement would enable you to achive pretty low moisture levels for less than 100 btus / lb of water removed.
Much more detail required to determine suitability of such.
