never seize lubricant
Looking for experienced users of never-seez. Can I use it as a pre-lubricant, and then add standard grease on top of it, and expect normal (or better) performance of the standard grease?
RE: never seize lubricant
Putting two different greases on top of each other is generally a bad idea if you don't know a little about what type they are, because different thickener systems (polyurea, Li-complex, Na-complex) are incompatible can cause the oil to separate out and so failure of the lubricant.
