Miniature DC gearmotors req'd (Globe motor delivery problem)
I have a problem, in that the delivery time for the Globe MIL-M-8609 gearmotors are longer than our requirements can stand.
I was going to order the SD gearmotor (.75" (19.05mm)dia)with the 2799:1 ratio, but I need an alternate supplier.
Does anybody know of a manufacturer that makes DC Gearmotors that have similar capabilities and quality as the Globe Gearmotors? The gearratio I can change somewhat.
RE: Miniature DC gearmotors req'd (Globe motor delivery problem)
stardelta and sreid,
thank you for your input, it looks like MaxonMotor may have what I need. In fact in the sizes I'm looking at they may be more capable than the Globe Gearhead I had looked at!
Thanks again!
Portescap make a vast range of beautifully engineered precision motors and gearboxes. They may have something to fit your application. Sit down before reading when the quote arrives - they are not cheap!
www.portescap.com
  I don't suffer from insanity. I enjoy it...
Maybe you would like a cheaper one,www.e-ds.cn
