Flow Over a Hump
Flow Over a Hump
Flow Over a Hump
Hello Everyone!
    I am conducting an experiment which is "Flow Over a Hump in an Open Channel" using water.  I just wanted to ask what type of channel would be best to use, flume, rectagular, or others?  Also , what materials are good for this experiment?>
Thanks, Richard
RE: Flow Over a Hump
I submit a flume. why, I like flumes.
pennpoint (nobody)
Best regards
pennpoint
I like flumes too, but I'd use a rectangular channel so I could change the hump geometry without a lot of fuss.  Maybe even dynamically, e.g. a sheet metal hump forced up by a hydraulic cylinder from the bottom of a plywood channel.
If you want to undertake a more ambitious, and practically useful, experiment, consider this:  Find a way to apportion water from a stream among consumers who are distributed along the stream, using passive, simple technology, that is effective over a wide range of stream flows.
Mike Halloran
Pembroke Pines, FL, USA
I did this for my final year project and used a glass sided rectangular channel and various thicknesses of mild steel plate to make the hump.
StephenA
What outcome/s are you looking for - an "experiment" without an outcome is not an experiment - just a waste of time and effort.
Also, I agree with "dicksewerrat (Civil/Environme)" --
It's your experiment - so you make the decisions.
Naresuan University
Phitsanulok
Thailand
