capture picture ?
capture picture ?
I'm fairly new to SolidWorks and have had questions regarding sketch entities. I sometimes like to send them off to another helpful person so that they can see what I'm talking about.
I want to capture a picture only of a pending sketch without having to exit the sketch....which is what SW wants you to do if trying to save as a jpg file.
I dont want or need the feature tree or toolbars to show up either, so how can I get a *jpg, or other pic, short of using Windows PrintScreen function and cropping out the extraneous portions ?
Thanx, Gatz
Thanx, Gatz
RE: capture picture ?
I believe you can download a demo version of it if you'd like to try it out.
Otherwise, exit the sketch change its color to blue so it looks active, dimension it, and save as jpg.
I'd choose the first option.
Adam
Solidworks 2005 SP01.1
Windows 2000
Shortcut to Microsoft Paint
Ctrl-C to copy
drag a box around the area you want
Ctrl-C
Ctrl-N (new paint image)
Ctrl-V (paste)
Much easier done than said, and you have a pretty decent assortment of file types to save to.
http://www.snapfiles.com/get/grabzilla.html
I've downloaded Grabzilla and am going to try it out.
btw, Michael, if you print to a PDF, do you have to have the Adobe program? I only have a reader.
Gatz
You will need a PDF creation utility though. If you have the PDF function in SW, you should be able to print to the "Bluebeam PDF printer".
Other free programs can be found at;
www.pdf995.com
www.cutepddf.com
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
