Transient Thermal Analysis
Hi
I am trying to model heating up an aluminium bar.
I used solid70 to model the data and applied convection on areas at some parts of the outer surface areas. Meshing is free with tets. The solution is nonlinear.
I want to find out the total heat (Joule or Btu) transferred to the system,
but i don't know how.
Can someone help me?
Thanks in advance
RE: Transient Thermal Analysis
The VM110 of 'Verification Manual" seems quite similar to your case.
CODE
/POST26
ESOL,2,11,,SMISC,1,HEAT   ! HEAT RATE FOR ELEMENT 11
INT1,3,2,1,,TOTAL_HT      ! INTEGRATE HEAT RATE OVER TIME
PRVAR,2,3
*GET,QTOT,VARI,3,RTIME,14.5
H-up
