Exported Model Accuracy
Good Morning
Is there any setting in SolidWorks that will affect the exported models accuracy?
Chris Tellers
Chris Tellers
RE: Exported Model Accuracy
Depending on what format you save as, you can click the options button at the bottom of the "Save As" dialog box and chose what may work best as far as accuracy and best representation of the model.
Is that answer of any value?
Adam
Solidworks 2005 SP01.1
Windows 2000
As a solid model part (dimensionally) ... not that I know of.
What are you actually trying to do? What problem(s) are you having?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris Tellers
Chris Tellers
It is an add-on for MasterCAM which allows it to read SLDPRT files directly. No Export/import. That may eliminate your problem.
We are still on Version 9.
Any idea where it is?
Chris Tellers
Chris
Have you tried the Multiple translator at http://w
Have you contacted MasteCAM direct to see if they have a version for '9'?
http://www.zenex.fi/master/SWdirect/solidworks.htm
Post an image of the problem. We export to MasterCAM daily via Parasolid, IGES, & STEP with no problems.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
