Cladding of Al-alloys with Ni-based alloys
Hi everybody;
has anyone experienced cladding of Al-alloys sheets with Ni-based alloys (Inconel)?
In case it was possible, which cladding method would be better?
I guess it should be done by roll cladding.
RE: Cladding of Al-alloys with Ni-based alloys
Explosion welding of aluminum/stainless is reported, so probably also aluminum/nickel-base would be feasible.
Roll welding of aluminum to stainless is reported difficult but possible, same as aluminum to nickel.
http://www.welding-advisers.com/
You may want to check wit JSW.
If the bottom of Aluminium is plated prior to roll bonding the problems nay be reduced.
There is a lot of stainless/AL bond experience from the cookware industry.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
