Extreme bore stroke ratio
I build and race small (150cc) 4 stroke roadrace motorcycles. The new engine I'm building has a bore of 75mm and a stroke of 35.5mm and is a water cooled 4 valve. Has anyone had any practical experience, as apposed to theoretical, on anything like this?
My 2 valve air cooled twin 150cc is making 27Hp at the wheel,thats 172 hp/litre and has reached the limit of development. I've got to get better than 30Hp to beat the dastedly 2 stroke 80cc watercooleds.
RE: Extreme bore stroke ratio
There are many tuners/racers in that forum with practical tips.
Sorry this doesn`t help you out at all but was just intrigued if you`ve found any obvious pitfalls and good advise as a response to your thread....
Many thanks.
Haven't progressed any further yet but will update IF it ever runs.
I knew the b/s ratio was tame compared to a multi, never gave dukes a thought...still a bit concerned that mines a single, think ill have to just build it up and find out i guess??
thephantom, good luck with the project, dont let the MANY frustrations and mind crunchingly annoying steps beat you down with development!
The motor runs real good and make quite good power from 6000rpm - 14500rpm
Many thanks.
This got the piston back to the correct deck height. I removed 1 link from the cam chain, skimmed the cylinder head as much as I could without the valve hitting the piston.
Fitted a 2mm smaller carb and away I went. This was stage 1.
Stage 2 I remapped the ignition curve.
Power output on a dyno jet chassis dyno at the wheel is 33+ HP. I used the 250 exhaust system. I'm yet to optimise
the exhaust system for the 200cc motor. The compression is still a little low. I need to work on this area some more.
I hope this info will help.
