Lines over raster image
When I print a Autocad layout white lines appear across the raster image. The lines dran in Autocad (2004) print correctly - it is just the raser image that has evenly spaced blank lines across it. On the screen the print preview is fine. Does anybody have a sloution to this problem?
RE: Lines over raster image
I've had this problem too.  I believe it is a problem with printer memory.  Not sure how to fix it, but that should at least point you in the right direction.
Check to see if you have the latest printer driver for you operating system.  I decided to check mine on a whim and now I don't have the white line issues.  At least with one photo anyway.  I tested this by using the older driver and came up with the white lines.  Then I printed the same photo with the new driver and I didn't have the white lines.
