PDMWorks Attribute in Part File Name
Does anyone know a way to have one of the PDMWorks check-in attribute labels (e.g. the description)appear in the file name?
Specifically, I would like to see in my assembly tree not just the part number that the file is named, but the description field from PDM Works.
Example:
File Name       Description
62206-164,     Adapter
~Jeff~
SolidWorks 2006 SP3.1 on WinXP SP2
Pentium(R)4 CPU 3.60GHz 1.00GB of RAM
RE: PDMWorks Attribute in Part File Name
I am not aware of a way to incorporate file parameters directly into the filename.  However, you can easily display both the filename and description in your SolidWorks BOM or a PDMWorks report.
If you click on "Select Labels" icon (next to the refresh button) you can select any or all of the following to be displayed in the PDM tree:
Document Name
Revision
Number
Description
Owner
Selecting document name and description should show what you want.
