12' tunnel cost
12' tunnel cost
I'm looking for an order of magnitude cost estimate for a 12 foot diameter drainage tunnel. It would be about 5,000 feet long and probably only 20 - 30 feet below the ground surface. The ground is assumed to be a mixture of sand, gravel, cobbles and silt with no bedrock. Groundwater is not likely to be encountered.
RE: 12' tunnel cost
