Torque and preload calculations for threaded tubing
I am trying to define torque and preload requirements for threaded tubing.
I am using standard fastener equations to determine pre-load at a particular torque value.
I used standard fastener equations to determine the tensile stress area. I then subtracted the area that is considered hollow on the tube. (Tensile area is less for tubing then bolts)
The part I am stuck on...
I have a pre-load value and a Tensile area.
How do I know if I am overstressing the threads on the tube?
My pre-load is 47,000 lbs
My material is 50,000 yield
Is my actual stress on the threads =Preload/Tensile area?
RE: Torque and preload calculations for threaded tubing
Cory
