Non conductive and Non absobptive material
I'm looking for material(s) that has parameters above, preferably in the 900 MHz RF range. What are its electrical and mechanical properties such that it produces those parameters
Anyone has suggestions?
RE: Non conductive and Non absobptive material
Temperature is at ambient. It needs to be solid as I would like to use for structural design. I'd be happy with tensile strenght close to Aluminum. Prefereably in structural shape like "I", "L", etc.
Kinsrow
two thoughts.
Fiber reinforced plastic, and epoxy (G-10) or thermoplastic like PPS (Ryton).  Select fillers carefully.
Or a ceramic.  Many of the toughened zirconias are very nice materials to work with.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thanks!!
Kinsrow
