Pressure vessel mounted on truck
Pressure vessel used to store yeast is being designed for 2 bar in accordance with ASME Section VIII Div.1.The tank will be used to transfer contents ( yeast ) from one brewery to other brewery. When in use this tank will be stationery.
This tank is for New Brubswick.
Question is that for CRN, do we need to comply with requirements of DOT also.
Thanks in advance
Thanks in advance
RE: Pressure vessel mounted on truck
you should contact New Brubswick Dept of Labour,
to register your vessel
genb
We transport crude oil samples (1000 cc) to the lab, and I believe there are regulations covering that.
