Cranked stud
Cranked stud
Cranked stud
I am trying to model stud for a model steam engine valve gear.
The diameter of the stud is 3/32" and threaded each end. This stud has a straight portion, is then bent at an angle of approximately 30 degrees for a distance and is then bent back parallel to the original length. The two bends are in the same plane.
How do I go about modelling this please?
RE: Cranked stud
try using the sweep command for the body of the stud
draw the trajectory then the profile
then add threads with helical sweep or as cosmetic thread
