Skirt supported vessel - seismic calcs
When using Table 9.14.5.1.1 of ASCE 7-02 what would you use as a value for R when calculating the seismic loads. There are two areas of the table the could apply. The 4th line of the table is for Elevated tanks, vessels, bins, or hoppers. Here a value of 2 is suggested for Irregular braced legs single pedestal or skirt-suported. The 12th line suggests a value of 3 for all other steel and reinforced concrete distributed mass cantilever structures not covered herein including stacks, chimneys, silos, and skirt-supported vessels that are not similar to buildings.
So, what would be the correct value to use for a tank supported at grade by a short skirt? I would lean towards using 3 because I feel that the value of 2 is for vessels supported inside buildings or other structures, not at grade. Any thoughts would be appreciated.
RE: Skirt supported vessel - seismic calcs
Tanks supported in a building are covered under mechanical equipment, rather than here.
I'm just a one man office so I haven't really discussed this yet with anyone.
Just thought I'd mention it.
-Mike
