Helical Gear design
Helical Gear design
Is there an automatic helical gear generator for CATIA V5. There's a pretty powerful one in Autodesk Inventor, where you can input the data and it will generate your gear. I was wondering if any have come across a similar one for V5?
RE: Helical Gear design
You would need to build a script or design table to do this.
If someone could make one, I'd happily publish it on CATBlog. If you'd like, you an also send me your details, and I'll take a crack at publishing a design table for such an application.
IF you are interested, follow my signature file, and use the contact form to email me.
Check out CATBlog!
Check out CATBlog!
