Filling 4mm letters stamped into SS with solder
I am polishing some SS plate (8" x 11" x 3/8"thick) and then stamping words into it using a set of letter punches. I want to fill the letters with some fairly bright silver colored solder and then polish the entire face to a mirror finish.
I need recommendations for a non-tarnishing soldier that will flow into these letter impressions (which are 4 mm tall) and stay put. I had thought of using epoxy with some kind of finely ground tin dust but I would rather do it with metal if possible.
Thanks in advance for your input.
RE: Filling 4mm letters stamped into SS with solder
Polish your plate, put your message in a DXF file, and take both to a laser cutting house. Ask them to laser engrave the message into the plate. Do a couple of test articles first, so you can get a feel for working with the medium.
Mike Halloran
Pembroke Pines, FL, USA
Thanks for the advice. In this particular case I don't need or want the precision of a laser engraving. What I'm more concerned with is a recommendation for how to fill in the impressions of the letter: what kind of solder, how hot etc.
Use a resin. It will stick well and not mess upt he rest of the finish. You can find a lot of epoxies that are filled with various things. Most will be dull, but many colors are available. You can get good contrat from you polished stainless.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
you have to find a solder that will wet your material. it is a flux issue. some of the silver solders have a flux that will bond to stainless you might try them.
pre-heat the plate in an oven and flow the solder in the letters with soldering iron assistance.
polishing is where your problems start, since it will preferentially remove the solder from the indentations.
the solder will not remain bright without a protecting layer and is hard to polish.
Mike Halloran
