Need help on sizing relief valves
I am trying to size some PSV's that have properties (hydrocarbons) with MW < 40 and Relief Pressure above 2000 psig. The API curve has a minimum of MW = 40 and a max pressure at 1000 psig.
For Fire case, how do I obtain the Latent Heat of Vaporization and Relief Temperature at the conditions mentioned above?
Can I be conservative and use Latent Heat of 50 btu/# anf relief temperature = (oper. temp./op. press.) x relief pressure?
I would appreciate any suggestion. Thanks.
RE: Need help on sizing relief valves
Good luck,
Latexman
Good luck,
Latexman
