Continuous RC beam û clear span considerations
I’d like to know how to determine the design moments in a continuous reinforced concrete beam when the clear span between supports is less than the span used in the beam analysis. For the negative moments, taking the design moment as the moment at the face of the support is typically done to account for this, but what about the positive moment? It seems that if the clear span between supports is less than the span used in your beam analysis the positive moment should also be reduced somehow.
TIA
TIA
RE: Continuous RC beam û clear span considerations
No, there is no reduction in positive moments in normal circumstances.
Whether this affects the positive moment to any great extent depends on the span, column width, beam depth, etc.
