electric annealer
electric annealer
I am in the process of designing a continuous electric annealer, to be added to an existing multi-die wire drawing machine. The drawn product is copper and my question concerns the square-root relationship between line speed and output voltage to the primary of the annealer's power transformer.Any clarification would be greatly appreciated.
RE: electric annealer
I suggest that you repost it on the Metal and Metallurgical Eng. forum as some of the guys that lurk there are involved in tube manufacturing, and they use continuous electric annealers.
rmw
The Power in a circuit that follows Ohm's law increases as the Square of the Voltage. If you double the line speed and need twice as much Power, than increasing the Voltage by the root of two will double the power. Likewise, for triple line speed increase the Voltage by the root of three for triple the power.
I have no idea if this answers your question.
Please follow rmw's advice and repost on another forum. Please give us a post if you find out that this is or isn't the answer.
yours
