Need help on nonliear material model constants?
Dear all,
I am using Ansys to model a micro device which contains deformation of a Polydimethylsiloxane (PDMS) Elastomer. I want to use HYPER56, HYPER58 to model this hyperelastic material, but I can not find the Mooney-Rivlin Hyperelastic Material Constants (I am using a 2 parameter Mooney-Rivlin model). Can someone point me where to find these information? Thanks.
ybzh
ybzh
RE: Need help on nonliear material model constants?
I am modeling a microvalve made of PDMS, and I need to find the Mooney-Rivlin Hyperelastic Material Constants of this hyperelastic material (I am using a 2 parameter Mooney-Rivlin model). Does anyone know the two parameters? Or can someone point me where to find these information? Thank you very much.
ybzh
You may find some of these constants lying around from ANSYS input decks that have been published on the web, or on scientific journal websites (such as www.sciencedirect.com for example). Check on www.matweb.com as well. However, it is highly unlikely you will get constants that will match your material precisely, so if you go searching in this way don't expect too much. Of course, the best thing to do is set up your own experiments with this material in order to obtain the M-R constants you need.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
You could have a look to this:
INSTITUTE OF PHYSICS PUBLISHING MODELLING AND SIMULATION IN MATERIALS SCIENCE AND ENGINEERING
Modelling Simul. Mater. Sci. Eng. 11 (2003) 195–231 PII: S0965-0393(03)57879-2
Finite element analysis and simulation of polymers—an addendum: a bibliography (1996–2002)
Jaroslav Mackerle
Best regards
Renaud / Post-Doc / Nanotechnology Group / Material department / Cranfield University/ England
I appreciate the suggestions.
