How do I make an irregular viewport
Currently when I make a viewport my only choice of shape is rectangular. I opened a template provided with AutoCAD which has an irregular shaped viewport.
How do I create a viewport from a polyline which can be drawn to fit around my title block and bill of materials.
RE: How do I make an irregular viewport
Under "mview" you would need options of "polygan" or "object".
Command: mview
Specify corner of viewport or
[ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/2/3/4] <Fit>:
Thanks, I was beginning to think I was looking in the wrong places, should have known.
You can import and edit a polygonal viewport (created in ACAD) into LT.
Lothar
ADT 2004
ACAD 2002
