machining environment
I am looking for specific documentation on temperature and humidity control in a machine shop environment.
We have a large repair/remanufacturing facility that we are assuming a 75 +or- 10 degree F temperature range. However, often the temperature rises to above 95 degrees F during the summer. The current climate control is provided by evaporative coolers. This has been ineffective, and introduces unwanted water vapor into the work space. Management would like to convert to chilled water/refrigerated air system.
What I need to know is if there is anything documented that represents an industry standard for machine shop recommended temperature and humidity operating ranges.
RE: machining environment
Fill what's empty. Empty what's full. And scratch where it itches.
