Transfromer Primary fuse opening
I need help in deteriming what causes the primary fuses of a 2500KVA, 13.8KV (Delta)- 4160/2400V Wye transformer to open during motor start-up.
The transformer primary fuses are 125A and the motor is 2000HP, 4160V, 242FLA. A reduce motor start is used as a starting method. It is set for 350% reduce start.
We can get one start but the second start opens the primary fuse for the transfromer. There is no other load connected (only the 2000HP). Start current of 1045A for 4.5 seconds was captured using a recorder.
Any suggestions would be very greatful.
RE: Transfromer Primary fuse opening
Check the time/current curve of your fuses.
Have you changed to a different type or rating of fuse lately?
Have you changed fuse manufacturers?
I get 104.6 amps rated current for the transformer primary.
It looks like your fused for 120% of full load. Have you considered larger fuses as per NEC table 450-3(a)(1), 300% or NEC (2)a, 250%
That would be about 300 Amps and 250 Amps respectively.
If 125 Amps gives you a start and a half, 250 Amps will probably do the job.
yours
waross, if you are going to quote the NEC, please get a current version or mention which version you are using each time. Per the 2005 edition, the only relevant table is 450.3(A). I happen to remember you mentioning the 1996 edition (2005 is the third since then) but others might not and might be confused trying to find your references; thanks.
Your point is well taken and I apologise.
I will in future quote my edition. I am a little far from home to upgrade just now.
yours
