HEAT RATE GAS TURBINE
Hi everyone.
I'd like to know if there is a way to know (graphics, formulae, etc.) the heat rate for gas turbine that is not operating at full load (22MW, 93F Tamb, sea level) but at 19 MW, 59F, sea level.
Thanks in advance.
Thanks in advance.
RE: HEAT RATE GAS TURBINE
OEMs may be able to give you some correlation in a graphical form to predict what you are asking for.
I trust this helps.
Best wishes,
gtsim
