carrier frequency and output frequency
What must be the relationship with the carrier signal and modulator(output) signal. I mean at least what must be the ratio between them? Can i get a 1KHz spwm signal with 7KHz carrier signal?
RE: carrier frequency and output frequency
It is almost like the Nyquist frequency - but reverse. If your motor inductance filters the carrier frequency very well, then you can go close to motor frequency = 1/2 carrier frequency. At least in theory. And with the motor acting as a brick-wall filter.
But since the motor is a first order low pass filter (6 db/octave) it will not work. You will probably need something like carrier = 10 times motor frequency or better.
1000 Hz motor frequency at 7 kHz carrier is doable, but be prepared to have some interference between carrier and motor frequencies. An output filter could perhaps improve the situation.
Gunnar Englund
www.gke.org
Asynchronous modulation usually require ratios of at least 20.
Gunnar Englund
www.gke.org
