Problem with Sheet metal design: The face selected must be planar?
Hi Everyone,
I tried to create a stamp with the self-defined punch and die. But when I tried to apply them to a surface(planar) with the user stampling tool, the system gives the error: "The face selected must be planar"?
What should I do? This message seems very popular to be seen in the sheet metal design.
-Zimmer
RE: Problem with Sheet metal design: The face selected must be planar?
Sheetmetal Design only works with Planar Walls (and in a few cases Cylindrical and Cones).
If you have a compound surface, you need to use Aerospace Sheetmetal Design.
Never mind. I restarted the machine and this time catia works.
Thanks catiajim anyway, I will try Aerospace Sheetmetal Design myself since I have not help file for the aerospace sheetmetal now.
-Zimmer
