Best standard or set of standards for metallurgical lab
I am just trying to find the best standard or set of standards for low carbon steel chemistries an properties. We are a relatively new metallurgical lab and our scope has just increased significantly. Our range of materials is basically 1030 and below but also includes some chinese, astm, and other oddball specs. I'm looking at Handbook of Comparative World Steel Standards: Third Edition but before we go spend $400 + on one book I'd rather know if there is something better. Any help on this would be appreciated.
RE: Best standard or set of standards for metallurgical lab
Are you in the US?
Are you A2LA?
Are you doing Arc&Spark chemistries & YTE mechanicals?
Then you likely Need ASTM A & E books... (these contain steel specifications (A-book) and test methods (E-book).
Do you deal with automotive sheet?
Then you will need the SAE J-series book.
These book are expensive, but WAY worth it!
I am not sure about the exact rules for A2LA or ISO 17025 accreditation, but I believe it is not enough to have a reference handbook, you must have the actual standard and also at the latest revision level. This means purchasing the appropriate ASTM, SAE, etc. standards from the respective organization or from one of their licensees like Global Engineering Documents.
Regarding handbooks, this topic was discussed somewhat in the following thread:
thread330-77902
If you do purchase the 3rd edition of ASTM's Handbook of Comparative World Steel Standards, please post your thoughts here as I would like to see if the product has been improved.
Cheers
You should definately have a copy of the ISO 17025 spec. and begin following it even if you dont need to.
