WinSocket Error???...Help!!!
Ok, i tried to install I-DEAS NX11. But when i want to start it the typical error 'loss of communication with i-deas license daemon'. Ok, then i looked for the failure.
lmtools gave me following message:
License server status: 7610@BEAT
License file(s) on BEAT: C:\Programme\I-DEAS11\sec\EDS_ID11.lic:
lmgrd is not running: Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: BEAT
License path: 7610@BEAT
FLEXlm error: -15,578. System Error: 10038 "WinSock: Specified socket is invalid"
Ok, this is my license file:
SERVER BEAT 000b6a148dc8 7610
DAEMON eds_id11 C:\Programme\I-DEAS11\sec\ options=C:\Programme\I-DEAS11\sec\eds_id11.opt
INCREMENT FLEXLM_RL eds_id11 11 permanent 2147483647 061B14AFA581
PACKAGE CoreMasterModeler eds_id11 11 E7892DD443A5 \
COMPONENTS="MasterModeler_C MaterialDataSystem_C \
3D_IGES_Translator_C RPT_Translator_C VDA_Translator_C \
SET_Translator_C IDEAS_Plotting_C"
FEATURE CoreMasterModeler eds_id11 11 25-jan-0 1 DB6CEF1110B1
PACKAGE MasterDrafting eds_id11 11 A088ED659A26 \
COMPONENTS="Drafting_D 2D_IGES_Translator_D DXF_Translator_D \
IDEAS_Plotting_D"
FEATURE MasterDrafting eds_id11 11 25-jan-0 1 DBE07B7D6E8B
FEATURE SurfacingSet eds_id11 11 25-jan-0 1 1744B59FEED6
PACKAGE AssemblySet eds_id11 11 8B0FC98C5C7A \
COMPONENTS="MasterAssembly_C ToleranceAnalysis_C"
and so on....
The strange thing is, that when i want to start daemon 'lmgrd.exe' my processor is used to capacity (100%), but nothing happens...
So i thought, that maybe the port of the daemon is incorrect. I saw some license file of you where the port is set to '7610'. So i changed mine in the same way (originally installed with '7611'). But it didn't help.
ok, this is my log file:
FLEXlm (v8.1a) started on beat (IBM PC) (1/26/2006)
17:24:23 (lmgrd) FLEXlm Copyright 1988-2002, Globetrotter Software, Inc.
17:24:23 (lmgrd) US Patents 5,390,297 and 5,671,412.
17:24:23 (lmgrd) World Wide Web: http://www.globetrotter.com
17:24:23 (lmgrd) License file(s): C:\Programme\I-DEAS11\sec\EDS_ID11.lic
17:24:23 (lmgrd) lmgrd tcp-port 7610
17:24:23 (lmgrd) Starting vendor daemons ...
17:24:23 (lmgrd) License daemon startup failed:
17:24:23 (lmgrd) CreateProcess error code: 0x3 File= C:\Programme\I-DEAS11\sec\
17:24:23 (lmgrd) Started eds_id11 (pid 4984)
17:24:23 (lmgrd) license daemon: lost all connections
17:24:23 (lmgrd) This is an internal error. lmgrd will now
17:24:23 (lmgrd) attempt to re-establish contact with other daemons.
17:24:23 (eds_id11) Using options file: "C:\Programme\I-DEAS11\sec\eds_id11.opt"
17:24:23 (lmgrd) Started eds_id11 (pid 8068)
Ok, so i really don't know any further. I don't know whats with this Winsocket failure.
So please can somebody help me???
Server name: BEAT
IDEAS_Plotting_D"
and so on....
RE: WinSocket Error???...Help!!!
If so, using the FlexLM GUI what does it report when you Start the daemon?
I'd also leave the port the same as installed. 7610 was used for 10, but that doesn't mean it should be used for 11.
i think you mean with FlexLM GUI the lmtools.exe?!?! ok, if it is so, he reports that the server is started successfully...but the server status is like written above...and my processor is used to 100% capacity and nothing changes...so the problem is that he can't start the lmgrd.exe, but i don't know why...
If you're on XP then:
Control Panel
System
Advanced Tab
Environment Variables
Under the System Variables pane select New
Against Variable Name type LM_LICENSE_FILE
Against Variable Valie type C:\Programme\I-DEAS11\sec\EDS_ID11.lic
OK
OK
OK
Reeboot your machine
By FlexLM GUI I mean the black FLEXlm icon in the Control Panel that should have appeared after installing I-DEAS (it does for all versions up to 10 but haven't loaded 11 yet) It's the FLEXlm License Manager.
On the Control pane your looking for
"<Hostname>: license server UP (MASTER)"
when you select the Status button.
One more thing to check, under
Network Connections
Local Area Connection, RMB Properties
TCP/IP
Properties
Advanced
WINS tab
Is the "Enable LMHOSTS lookup" checked?
I forgot something to say: I'm using at the same time ANSYS 9 Workbench for some quick simulations, so i have 2 lmgrd-services...
looks in the license-manager like this:
h
So i had an idea and changed the path to the lmgrd.exe, now its the path to the lmgrd.exe ANSYS is using...
h
Then i startet this service and following message appeared:
h
Status -
Flexible License Manager status on Fri 1/27/2006 20:51
[Detecting lmgrd processes...]
License server status: 7611@beat
License file(s) on beat: C:\Programme\I-DEAS11\sec\EDS_ID11.lic:
beat: license server UP (MASTER) v9.2
Vendor daemon status (on beat):
eds_id11: The desired vendor daemon is down
1) Check the lmgrd log file, or 2) Try lmreread
Feature: FLEXLM_RL
Vendor:Host: beat
License path: 7611@beat
FLEXlm error: -97,121
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Feature usage info:
Users of FLEXLM_RL: Cannot get users of FLEXLM_RL: No such feature exists
Feature: FLEXLM_RL
FLEXlm error: -5,222
Users of SurfacingSet: Cannot get users of SurfacingSet: No such feature exists
Feature: FLEXLM_RL
Users of ProductDesignApplications: Cannot get users of ProductDesignApplications: No such feature exists
Feature: FLEXLM_RL
Users of ProductDesignUtilities: Cannot get users of ProductDesignUtilities: No such feature exists
Feature: FLEXLM_RL
Users of SheetMetal: Cannot get users of SheetMetal: No such feature exists
Feature: FLEXLM_RL
Users of HarnessDesign: Cannot get users of HarnessDesign: No such feature exists
and so on...
ok, lmgrd is started, but now there are some other problems...aaaargh... maybe there is a problem concerning existing ANSYS' license daemon...but i think it has to work anyway
maybe you have some ideas
in anticipation
steffen
i`ve the same prblem with my I-DEAS NX11 on WinXP OS.
The license service use 100% of CPU.
I found simply way:
i`ve just installed another OS - Win2000. (with service pack up to 3!! - above SP3 i`ve got the same error!!!)
So now, i`m having 2 OS:XP SP2 and 2k .
but it isn`t a rule.Just simply, I-DEAS works on some workstations and on the rest-NOT
pozdrawiam
cad - designer
i-deas 11nx sworks 2006 ug nx 4.0
IMB InteliStation M Pro
First off all: Thanks to you...you were really engaged to help me...thanks!
Today i installed the same version on a second partition (secondary hard disk) with the same OS (Win XP SP2)....and it works!!! Don't know why...but it works....
Greetings from Germany
i`m glad that your i-deas is working.
I hope, that my treat was helpful.
Greeting from Poland
cad - designer
