intake air louvre pressure drop
Hello
Where can I finds guides / rules of thumb to evalute the pressure drop occuring over an intake louvre covered with mosquito gauze?
RE: intake air louvre pressure drop
Intake louver pressure drop you can get from louver manufacturer.
The AMCA standard for louvers is to test a 48" x 48" louver (with the specific blade, head and jamb design) for pressure drop and water penetration.
As a general rule - most people consider this test to be representative of all louver sizes and it is but I always recommend that if the louver is short - less than 4 blades tall - use the pressure drop with a grain of salt.
Just a recommendation - drainable head and drainable blade with a jamb that channels the water away really gives you a lot of safety factor for water penetration.
