Surface Display
Surface Display
Sorry for asking what is probably a really basic question but I am not a UG user.
In NX2.0 or 3.0 if I have 2 surfaces joined what option allows me to visibly see the difference between internal edges and boundary edges.
Thanks in advance
Thanks in advance
RE: Surface Display
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Surface Display
RE: Surface Display
If surface quality isn't really much of an issue, then just check the Sheet Boundaries box & then OK & NX should highlight all free edges with a colored outline.
If you wish to display free edges on a sort of permanent basis, about the only thing you can do is change the line color, font or width for smooth edges. However, do this will NOT assist in determining free edges, it basically shows tangency & above when met. If that is more along the lines of what you want, click Preferences->Visualization then click the Visual tab. Check the Smooth Edges box then just to the right & down a little are the color, font & width settings.
Hope this helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
