shared resources?
shared resources?
I tried to set up a master project file that references several external projects. The resources are the same for all external projects. My problem is that I don't know how to make the master project file realize that these are shared resources between the projects. For example, "Resource1" is repeated 5 times on my resource sheet because he is listed on 5 projects. As a result of this I can't do any resource leveling between projects using the master project file.
Is there a way to do this, or am I going about it all wrong?
Thanks in advance.
Thanks in advance.
RE: shared resources?
