Exporting points from CATIA V5 to excel
I have a part which contains only points. They are all named to identify them. I am trying to export these and input them into an excel file. How do I easily export the values and names of these points?
RE: Exporting points from CATIA V5 to excel
Make a design table.
You'll have to select the design table icon, then multi-select the points from the tree. (it doesn't work by dragging a window - must use tree)
Next, when it asks for parameter values, I would suggest that you use the filters.  Points have 3 components - X, Y, and Z values, and these are regarded as a "length" parameter.  Multi-select the X, Y and Z parameters, and add them.  When you click finish, your point values will be added to a spreadsheet.
From there, you can externally modify the layout.  Remove the parameter names, cut and past them into a side-by-side arrangement, whatever.  It's very easy to do.
Hope that helps.
Check out CATBlog!
Unfortuanately design tables are a new thing to me. When I select all the points from the tree in the design table I can only get one column or row and all the values are zero.Is there a tooling option I need to activate? Is there an option to create many columns/rows? Thanks for your help.
In my opinion - design tables are as easy, or easier, than using the table function in drafting.
To nivlacburns: You seemed to have not selected the parameters.  Check the documentation for design tables.  I would suggest that you search your computer for the following files:
cfyugat3006.htm
cfyugat3320.htm
cfyugat3310.htm
cfyugat3330.htm
If you are new to this, it's a great opportunity to become savvy with a new set of tricks.
Check out CATBlog!
Sorry about your Blog Solid7...but you know you can use / copy the code... ;)
I wrote an R14SP4 VBA script to get XYZ of points in a text file...
check CatiaV5Forum
go Download / General Script program
Enjoy !
Eric N.
Thanks for the tip, Eric.
I didn't know that you had written a script to handle this sort of thing.  I remember the points from excel to Catia, but having the reverse is a very cool thing.
Thanks for sharing.  With your permission, I'll copy it over, and credit you...
Check out CATBlog!
hi,
you gotta wait for the catiav5forum admin to make it available...
Eric N.
Watching and waiting...
Check out CATBlog!
and hoping..
Eric N.
