what is the difference ?
i'm recently graduated engineer and i want to know what the difference between the following in using ?
the switchgear and the circuitbreaker
miniture c.b and moulded case c.b
sectionlizer and bus coupler
sf6 and vacuum c.b
and thanks
sf6 and vacuum c.b
and thanks
RE: what is the difference ?
Google this ISBN 0070220050
Good technical sources could be find, for instance, in the ANSI/IEEE Standard 100, ANSI C37.50&51, UL489 & 1066, NEMA AB-1& SG3, NEC, etc. There are technical articles in magazines, white papers, manufacturer catalogs and web sites in general.
PS: Here are 3 examples:
http://ww
h
ht
that is all true, cuky2000.
ahmadnece, listen very carefully to what cuky2000 said.
i'm an electrical power engineer, graduated 3 years ago, and i can admit it that i've learned nothing at my collage here in egypt, except from my frequent surf via technical data & information avialable on the internet.
i learned an important engineering rule for myself, never ask before searching.
try it,....the internet contains such tremendous valuable technical information, via search engines.
man, just surf and find out, trust me.
The Siemens website is heavy going to find what you are looking for, Schneider's is good for current products and a total waste of time for legacy stuff, and ABB's is pretty good all round.
I don't suffer from insanity. I enjoy it...
