Wind Factor In Intact Stability Calculation??????
Hi all,
I have heard that a new rule is coming into force soon or might be already in force that i dont follow that wind calculation has to take affect while calculating the intact stability and the booklet shall include that calculation as well.
Is it true ? If it is so , then which rule is it ? where should i refer to ?
GOKHAN
Naval Arc.& Marine Eng.
RE: Wind Factor In Intact Stability Calculation??????
Brian E. Trenhaile, P. E.
Naval Architect and Marine Engineer
Hawaii Marine Company
www.hawaii-marine.com
Thanks for the reply, I knew that the wind factor is already taking force in the calculation of Intact Stab. but what i m informed is a new rule which i m not clear about it.
Anyway thanks for your time.
GOKHAN
