Draft Qs SW2005
Draft Qs SW2005
Draft Qs SW2005
We have a large hollow Aluminum feature that resembles a box.  28" Tall x 8" wide x 4" thick, the split line travels in a zig zag fashion down through the center.  Unfortunately when adding draft to each side the edges are at different heights due to the 3° of draft over the length of the face.
Is there anyway to select a variable amount of draft will having a minimum of 3°?
RE: Draft Qs SW2005
You may need to post an image to get your point across.  See the FAQs for that.
Meanwhile, have you tried the parting line draft instead of draft from a plane?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: Draft Qs SW2005
Ok Here ya go,
We are trying to keep all the outside edges uniform in thickness, the only way to do this is to use the step draft function.  Problem is now there is the raised section along the split line.
I was think perhaps maybe a filled surface would be able to fix this.  To bad can't specify a minimum draft angle and let solidworks compute all the draft angles.
RE: Draft Qs SW2005
christianroth ... Sorry, I don't have an answer for your question, but I do have a request for you.
Please make sure future images you post are => 400 pixels wide. Posting large images can really distort the threads layout. See FAQ559-1100 & the Process TGML section.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Draft Qs SW2005
I was going to mention the step draft, but as you point out, it does create a ledge at the PL.  If that's not acceptable, then there's only one other method I can think of which is to do a loft.
On one side of the loft use a composite curve to collect the edges of the PL, and draw a straight line on the other.  Loft the stepped PL to the straight model edge.  I would do this as a surface loft and use the Replace Face function.
[img www.dezignstuff.com/page008.gif]
The yellow faces were done using the regular PL draft tool, the orange were made with the lofted surface and cut with surface tools.
The "draft to edge" function would be very useful.  I'll submit an enhancement for that.
matt
