selectively display sketch component name
Is there a way to display the name of particular sketch components, outside the sketcher (inside it too?)?
For example, I have a sketch with three lines. I re-label each line (using the contextual Properties command) from "Line.1" etc to "length", "height", "hypotenuse" or similar.
Can I have the new names appear on the screen next to the line? (In UG NX3, you'd name the line similarly to CATIA, and then you'd enable "Object Name Display" "In Work View", under "Vizualization Preferences".)
Thanks; sorry if I'm not being clear...
RE: selectively display sketch component name
I think, if I understand correctly, you want to label the object, but the label is automatically generated from the "name" property?
Check out CATBlog!
I definitely can view them in the tree as you are suggesting. OTOH, if it's possible, what I REALLY want is to see the name displayed ("labeled" if thats the right way to say it) next to the actual geometry.
Is it possible?
thanks.
The best way I can think of is to add a text annotation (FTA workbench) on top or near to the geometric element. (I'd use the one that's always normal to the screen) I don't think you can automatically label the text based on the element name, although that can probably be done with a macro or script.
Any special reason why you want to do this? (other than you can do it in NX)
My specific reason was I'm working up a couple of engineering diagrams, where it'd be very handy to see the labels of the lines right next to the geometry on the screen. (And I don't want to go thru the process of making a print per se; I want to just see this in the modeling workbench, on the fly.)
