File management questions?
1.) How do I remove a file from session/memory? If I make changes to a part model and then close without saving, how do I completely remove it from session/memory, so that the old configuration is used?
2.) Is there a way to take an open part model and the associated drawing and save copies of them as new file names? Such that the new drawing will use the new part model file that was created.
RE: File management questions?
