PDF orientation
PDF orientation
PDF orientation
My .SLDDRW is oriented "Landscape". So it prints Landscape.
But when I save it as .PDF file, and than open with Acrobat7.0, the .PDF "sheet" is ALWAYS "portrait" and the dwg in it is "Landscape", no matter what I tried to do.
Any clues how to force the .PDF "sheet" to be "Landscape" as well ?
RE: PDF orientation
Quote:
print setup, landscape, then pdf
Nope, does NOT work
RE: PDF orientation
Is it only this file? If all files, then check printer settings. If only the one file, try on other PC.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: PDF orientation
Print ---> Page Setup ----> then on the top portion of the dialog box their are two settings (1) Use system settings (2) use this document settings  What is your set to?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
RE: PDF orientation
All files.
RE: PDF orientation
Tried both - makes no difference
RE: PDF orientation
Have you tried printing to a file using the Bluebeam or any other PDF printer device. You get more options that way. The Save As > pdf method is the quick no-frills way.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: PDF orientation
Please explain in more detail - I don't get it.
BTW, I am NOT printing, just creating .PDF file using SW2005 SP4.0  and  Save As ....PDF
I also noticed, that even though I set Landscape in the page set up and save (no print though), the Landscape is there, but AFTER I Save As ...PDF, and than check Page set up, the setting is - PORTRAIT.
Why the hell the Save As ...PDF changes that (i.e. from Landscape to Portrait) ?????
RE: PDF orientation
Have you tried all the suggestions in the threads CBL referenced?  I'm not sure if this is the same problem I've had in the past, but this fixed my problem:
Another thing to try is to make sure that you have the permissions set up correctly on the Bluebeam PDF printer.
Access the printer through the Control Panel, go to Properties, and on the Security tab make sure that your users have the ability to Manage Printers and Manage Documents.  We ran into this problem here and changing the printer setup fixed the problem.
RE: PDF orientation
BTW, if I try to Save As  .JPEG, it looks normally
RE: PDF orientation
There is NO security tab - here are the tabs I found in my Bluebeam PDF Printer Properties Window:
- General
- Sharing
- Ports
- Advanced
- Color Management
- Device Settings
RE: PDF orientation
The PDF printers aren't physical printers ... just software "devices". You can create a PDF by sending (printing) a file
to any of the ones you may have. (Bluebeam, Adobe, pdf995, etc).
File > Print, select PDF printer of your choice, choose whatever options you want under the Properties and
Page Setup sections and then OK
cheers
RE: PDF orientation
Do you have administrator privileges on your machine?  If not, that probably explains why you don't have a security tab.
RE: PDF orientation
No, I do not.
RE: PDF orientation
I'd suggest getting an admin to tweak those settings and try generating your PDF again.
RE: PDF orientation
Kina "not very clear enough for a dummy", but anyway, my admin is back and after about half an hour of trying and swearing we managed to get it working.
It looks like on XP Professional you need to be set as a Power User to have your printer settings being accepted by the OS.
Thank you guys for the help !!
