Hatching .sldprt
Hatching .sldprt
Can a surface area be hatched within the part. Or is it only possible in the drawing (sw2005)
Thanks for the advice
Adam
Solidworks 2005 SP01.1
Windows 2000
RE: Hatching .sldprt
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Adam
Windows 2000
Can you post a screen capture of the problem you are seeing, and/or an image of what you are trying to do.
(view is shaded in the drawing)
ht
You can see the hatch through the part
Adam
Windows 2000
If you used the Area Hatch/Fill then that must be a glitch/bug/limitation.
You are running SW05 so the texture will not help you in the drawing. You would need SW06 for that.
What are you trying to represent using the hatch?
If you can live with a shaded view, you could simply colour the surface in the model.
thanks for the help though.
Adam
Windows 2000
Chris
AutoCAD 05
FAQ559-1100
FAQ559-716
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 1/12/06)
SW 2006 SP 3.0
By the way, this process was very slow in SW2005 - much better in SW2006.
Adam
Windows 2000
