Compression ratio x compression pressure
What is the reason why with a compression ratio of 1:8,5 you should get between 11 and 13 bar of compression pressure? You shouldn't only multiply compression ratio times the atmospheric pressure?
Thank you.
Thank you.
RE: Compression ratio x compression pressure
http://victorylibrary.com/mopar/cam-tech.htm
