"Residual Stress" vs "Microstrain"
What is the difference between the terms "residual stress" and "microstrain" or "microstress"?
"Residual Stress" vs "Microstrain""Residual Stress" vs "Microstrain"(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: "Residual Stress" vs "Microstrain"
When measurements are made using stain gages the output is frequently quoted in microstrain.
If you are talking about measurements of residual stress using stain gages and hole drilling or similar techniques the results of the residual stress measurements could well be listed as microstrain numbers.
The term microstrain usually is used when discussing results from strain gauges. Strain is the change in length divided by the original length of the specimen, and so microstrain just means YY.YY x 10-6 m/m (same as µm/m). Microstress would be the avlue obtained when multiplying microstrain by the Young's modulus of the material in question.
What are some common ways to characterize residual stress?
Are the micro properties of stress and strain substantially different than at bulk scale?
Check out the following links for more information on residual stresses, shot peening, x-ray diffraction, etc.:
Check out the following references:
http://www.protoxrd.com/residualstressinfo.htm
check out the various applications, publications, etc.
http://www.lambdatechs.com/html/resources/dn27.pdf
a great deal of information available including publications
http://www.shotpeener.com/library/pdf/1984034.pdf
many other items in this library on the subject
http://www.lanl.gov/contour/
http://
http://www.metalimprovement.com/shot_peening.php
http://www.shotpeening.org/ICSP/confrns.htm
click on any of the conferences from 1 to 7 to freely download papers
Depends on the cause of the residual stress. If it is due to highly localized changes such as a butt weld then yes the residual stress pattern will tend to show a peak close to the weld center-line and be balanced by opposite stresses of slightly longer range in the base material / heat affected zones on either side of the weld.
If the residual stress is caused by a more general effect such as bulk metallurgical transformation then they might be more uniform.
You see it in sheet when you slit. If you have a slitter with a looping pit you will see how much longer one strand is than the one next to it, and they were attached.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Cyril Guichard
Mechanical Engineer Consultant
France
Ed you get a star for this! Thank you! Thank you!
My first job out of masters school was on a service center floor, The first machine I was on was the slitter. (I only got to set 3 heads, too bad that was the interesting part.) I asked everyone there why some strands were longer than others, no one knew.
(I also learned why the overarm might be one of the most important parts of the machine, and what happens when .100" HRPO slips out from under it, slaps over, and knicks your knee. If I was 2" closer I wouldnt have a kneecap.)
Nick
I love materials science!
