how do you work out point load
how do you work out the point loads on fully extended riggers on an 35 ton att crane
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: how do you work out point load
Otherwise it can be approximated. Shaperio has an excellent rigging book that explains how to do this. Most crane manufacterers do not provide enough data to directly calculate, so you may need to make some educated assumptons about weight distribution in certian components of the crane. It is a calculation that requires some time to do. For large cranes working at close raius, the controlling loads may be the back outriggers with no load in the falls. Picking over a corner may be the most stable configuration, but it too may generate your controling load. Best bet is to consult the manufacterer or a rigging engineer.
