B31.1 weld prep
B31.1 weld prep
I have a weld prep that must comply to B31.1, but is not on round pipe, but on a 2'x6' rectangular duct made of 3/4" low carbon plate. The pressure is less than 300#.
What I want to do is to prep the weld with a square cut (no bevel) on one side, and a 45 degree bevel on the other. 1/16" gap, with a 1/2" backing strip. The backing will remain in place, and the weld is full penetration.
The big difference is that the bevel will be ground on one side only instead of symmetrical. Can anyone think of a provision in the code that prevents this prep?
RE: B31.1 weld prep
RE: B31.1 weld prep
RE: B31.1 weld prep
